Introduction
If you wish to upgrade your battery life, here is how to replace the battery on your HP Mini 311.
Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
Ajouter un commentaire
Slide the battery away from the device to remove. Slide the battery away from the device to remove.
  • Slide the battery away from the device to remove.
5 autre(s) ont terminé cette réparation.
Christian Santoyo
Membre depuis le 31/01/2013
369 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-4, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 23
Total : 1,378
