Aller au contenu principal
HP Mobile Thin Client mt41 Fan Replacement
Ce dont vous avez besoin
  1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: étape 1, image 1 de 2 HP Mobile Thin Client mt41 Fan Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  2. HP Mobile Thin Client mt41 Fan Replacement: étape 2, image 1 de 2 HP Mobile Thin Client mt41 Fan Replacement: étape 2, image 2 de 2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  3. HP Mobile Thin Client mt41 Fan Replacement: étape 3, image 1 de 1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  4. HP Mobile Thin Client mt41 Fan Replacement: étape 4, image 1 de 1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  5. HP Mobile Thin Client mt41 Fan Replacement, Fan: étape 5, image 1 de 2 HP Mobile Thin Client mt41 Fan Replacement, Fan: étape 5, image 2 de 2
    • Using a J1 head for your screwdriver, remove the 4 surrounding screws.
  6. HP Mobile Thin Client mt41 Fan Replacement: étape 6, image 1 de 1
    • Keep your screws close by, and slowly remove the CPU fan.
  7. HP Mobile Thin Client mt41 Fan Replacement: étape 7, image 1 de 1
    • Be mindful of wires, the final step is to unplug the fan from the motherboard, at the base of red and blue wires.
William Rapp
Membre depuis le 02/08/18
171 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 9
Total : 356
