Introduction
Paper trays are easy to break but thankfully it is an easy repair with only one tool required.
Pièces
Aucune pièce nécessaire.
Begin by turning your printer upside down.
  • Begin by turning your printer upside down.
  • It can be helpful to position an object beneath the printer to keep it level while you work on it.
Ajouter un commentaire
Use the T-10 screwdriver to remove the two 11-mm screws.
  • Use the T-10 screwdriver to remove the two 11-mm screws.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Pull the paper tray out until it hits the stops on either side of the tray.
  • Pull the paper tray out until it hits the stops on either side of the tray.
Lift up on one side of the black plastic bar with one hand while pulling the paper tray out of the printer with your other hand. The side of the tray should slide away from the printer a little bit. The side of the tray should slide away from the printer a little bit.
  • Lift up on one side of the black plastic bar with one hand while pulling the paper tray out of the printer with your other hand.
  • The side of the tray should slide away from the printer a little bit.
Repeat the previous step but for the other side of the tray. Repeat the previous step but for the other side of the tray.
  • Repeat the previous step but for the other side of the tray.
The paper tray should now be free to slide away from the printer.
  • The paper tray should now be free to slide away from the printer.
Tyler Allen
Membre depuis le 24/01/2018
324 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G3, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 28
Total : 98
