Introduction
This guide will show how to remove the printer's encoder strip.
Pièces
Aucune pièce nécessaire.
Open the main lid as far as it will go.
  • Open the main lid as far as it will go.
  • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
  • Open the lid further.
Ajouter un commentaire
Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise. The two screws above the screen assembly are deep so you may need a long screwdriver. The two screws above the screen assembly are deep so you may need a long screwdriver.
  • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
  • The two screws above the screen assembly are deep so you may need a long screwdriver.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Grab the main cover and lift it up slightly.
  • Grab the main cover and lift it up slightly.
  • Do not pull too—there is a cable connecting the cover to the printer.
Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out. Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
Push the hook that is attached to the encoder strip towards the center of the printer. Hold the hook pushed in and pull the strip off of the hook.
  • Push the hook that is attached to the encoder strip towards the center of the printer.
  • Hold the hook pushed in and pull the strip off of the hook.
  • Repeat on the other side of the encoder strip.
  • During reassembly, the black triangle on the encoder strip should be on the right side of the printer.
Carefully slide the encoder strip out from the carriage.
  • Carefully slide the encoder strip out from the carriage.
David J
Membre depuis le 24/01/2018
169 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S2-G4, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 51
