Introduction
Sometimes the battery for the motherboard on the HP Officejet Pro 8600 Plus goes bad. This guide describes how to replace the battery located on the motherboard.
Pièces
Aucune pièce nécessaire.
Turn the printer so the back is facing you. Put the printer in a vertical position by lifting its right side.
  • Turn the printer so the back is facing you.
  • Put the printer in a vertical position by lifting its right side.
Ajouter un commentaire
Remove the two 12mm T10 Torx screws on the top edge of the printer.
  • Remove the two 12mm T10 Torx screws on the top edge of the printer.
Rotate the printer clockwise so the bottom of the printer is facing you.
  • Rotate the printer clockwise so the bottom of the printer is facing you.
Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel. Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
  • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
  • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
  • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the side panel from the printer by lifting upwards toward you.
  • Remove the side panel from the printer by lifting upwards toward you.
  • For reassembly, slide the side panel from left to right into place.
Remove the four 6.5 mm T10 Torx screws from the motherboard.
  • Remove the four 6.5 mm T10 Torx screws from the motherboard.
Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
  • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
Remove the cables connected to the top of the motherboard by gently pulling them out of their ports. Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports. Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
  • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
  • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
  • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
Turn the motherboard over so the back is facing upward. Use the plastic opening tool to pry the battery out of place.
  • Turn the motherboard over so the back is facing upward.
  • Use the plastic opening tool to pry the battery out of place.
Remove the battery by grabbing its edges, lifting upward, and sliding sideways.
  • Remove the battery by grabbing its edges, lifting upward, and sliding sideways.
Mackinnon Buck
Membre depuis le 18/04/2018
410 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S16-G4, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 47
Total : 74
