Introduction
This guide will show how to replace the printer head for the printer.
Open the  printer head cover door by pulling the cover door.
  • Open the printer head cover door by pulling the cover door.
  • Power on the printer. This will move the print head to the left so you can access it.
  • Unplug the power cable from the back of the printer.
  • Do not power down the printer using the power button, as this will cause the printhead to move back to the right, making it incaccessible.
Ajouter un commentaire
Locate the printer head on the left side of the printer. Locate the printer head on the left side of the printer.
  • Locate the printer head on the left side of the printer.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull the white plastic tab on the right of the printhead toward you on an upward swing to unlock the printhead. Pull the white plastic tab on the right of the printhead toward you on an upward swing to unlock the printhead.
  • Pull the white plastic tab on the right of the printhead toward you on an upward swing to unlock the printhead.
Gently pull out the printer head. Gently pull out the printer head.
  • Gently pull out the printer head.
Scott
Membre depuis le 24/01/2018
313 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S19-G2, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 membre
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 59
30 derniers jours : 171
Total : 420
