Introduction
A damaged scanner glass will at best produce poor quality images, and at worst damage other parts of the printer or cause injury. Replacing the scanner glass only requires a couple tools and a little patience.
Pièces
Aucune pièce nécessaire.
Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
  • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
Ajouter un commentaire
With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
  • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
Once you have removed the scanner lid, locate the finger notch on the inside top left half of the bezel (control) panel cover.
  • Once you have removed the scanner lid, locate the finger notch on the inside top left half of the bezel (control) panel cover.
Place your index finger in the notch and lift up to unsnap the panel.
  • Place your index finger in the notch and lift up to unsnap the panel.
  • Set panel cover aside.
Use a T9 torx screwdriver to remove the 0.9 cm screw.
  • Use a T9 torx screwdriver to remove the 0.9 cm screw.
From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
  • From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
Disconnect the white ribbon cable by grasping it between your thumb and forefinger. Gently pull to release the ribbon from the green circuit board.
  • Disconnect the white ribbon cable by grasping it between your thumb and forefinger.
  • Gently pull to release the ribbon from the green circuit board.
Next, use a spudger to pry loose the flat ribbon computer cable by the plastic connection end and carefully separate it from the prongs on the button panel.
  • Next, use a spudger to pry loose the flat ribbon computer cable by the plastic connection end and carefully separate it from the prongs on the button panel.
  • Now the whole button should be completely disconnected from the printer.
  • Set button panel aside.
Using the T9 torx screwdriver, unscrew the seven 0.9 cm black screws on the top plastic frame around the glass.
  • Using the T9 torx screwdriver, unscrew the seven 0.9 cm black screws on the top plastic frame around the glass.
From the back of the printer, locate the two large plastic tabs as shown.
  • From the back of the printer, locate the two large plastic tabs as shown.
  • With your index fingers underneath each tab, gently and simultaneously pull the tabs towards you and upwards to release the tabs from the plastic clasps behind them.
  • Once these tabs are released, you should be able to remove the whole plastic frame that holds the glass.
Gently lift the glass/plastic bed from the edge on the side opposite of the button/control panel section. As shown in the second image, gently lift the glass pane up so that it is above the plastic tab that holds it into place.
  • Gently lift the glass/plastic bed from the edge on the side opposite of the button/control panel section.
  • As shown in the second image, gently lift the glass pane up so that it is above the plastic tab that holds it into place.
Proceed to slide the glass pane out and over the plastic tab to remove it completely from the plastic bed.
  • Proceed to slide the glass pane out and over the plastic tab to remove it completely from the plastic bed.
  • Replace the glass with your new glass pane. To fully reassemble the printer, follow these instructions in reverse order.
Amber Gabaldon
Membre depuis le 28/01/2014
325 Réputation
3 tutoriels rédigés
Équipe
New Mexico State, Team 1-4, Sheppard Spring 2014 Membre de l'équipe New Mexico State, Team 1-4, Sheppard Spring 2014
NMSU-SHEPPARD-S14S1G4
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 517
