Introduction
The scanner tray is the part of the printer that houses the entire scanner. It is connected to the printer by two hinges, 3 white strip wires, and 1 orange brown red and black wire. After the tray is removed the feed rollers can be cleaned, and printer carriage can be replaced.
Ce dont vous avez besoin
Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
Press down on the two plastic hinges to remove the upper portion of printer.
Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
Rotate the printer so the paper tray is facing towards you.
Gently lift the scanner tray up and away from the printer.
Press the gray plastic tabs inward to release the tabs from the printer.
Returning to the back of the printer, remove the scanner from the back hinges.
Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
