Aller au contenu principal
HP Pavilion 13-P110NR Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion 13-P110NR Battery Replacement, Battery: étape 1, image 1 de 1
    • Gently use the black nylon spudger to pry the back casing from the screen until it snaps apart.
  2. HP Pavilion 13-P110NR Battery Replacement: étape 2, image 1 de 2 HP Pavilion 13-P110NR Battery Replacement: étape 2, image 2 de 2
    • Flip the gray latch back and remove the blue and white band of wires from the green motherboard.
  3. HP Pavilion 13-P110NR Battery Replacement: étape 3, image 1 de 3 HP Pavilion 13-P110NR Battery Replacement: étape 3, image 2 de 3 HP Pavilion 13-P110NR Battery Replacement: étape 3, image 3 de 3
    • Pull the black and white wire out of the green circuit board.
    • Pull the red and black wire out on the other side of the device.
  4. HP Pavilion 13-P110NR Battery Replacement: étape 4, image 1 de 2 HP Pavilion 13-P110NR Battery Replacement: étape 4, image 2 de 2
    • Unscrew the three screws from the circuit board using a Phillips #00 screwdriver.
    • Unscrew two 4.0 mm Philips #00 screws from the left side of the battery.
    • Unscrew two 3.0 mm Philips #00 screws from the right side of the battery.
  5. HP Pavilion 13-P110NR Battery Replacement: étape 5, image 1 de 2 HP Pavilion 13-P110NR Battery Replacement: étape 5, image 2 de 2
    • Unplug the bound (red, white and black) wires connecting the battery and the motherboard.
  6. HP Pavilion 13-P110NR Battery Replacement: étape 6, image 1 de 2 HP Pavilion 13-P110NR Battery Replacement: étape 6, image 2 de 2
    • Carefully remove the battery without pulling the copper information transmitter out.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 538
