Introduction
This is a simple and straight forward procedure to replace the CD-Drive on your device. If your CD-drive has failed and will no longer read discs, then following this guide will help you regain a functioning drive.
Pièces
Aucune pièce nécessaire.
Locate the screw, will have a CD symbol next to it, and remove this 3.5 mm screw with a PH0 screw driver. Locate the screw, will have a CD symbol next to it, and remove this 3.5 mm screw with a PH0 screw driver. Locate the screw, will have a CD symbol next to it, and remove this 3.5 mm screw with a PH0 screw driver.
  • Locate the screw, will have a CD symbol next to it, and remove this 3.5 mm screw with a PH0 screw driver.
Ajouter un commentaire
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using your finger nail or a plastic opening tool, pull out the drive. Using your finger nail or a plastic opening tool, pull out the drive. Using your finger nail or a plastic opening tool, pull out the drive.
  • Using your finger nail or a plastic opening tool, pull out the drive.
Alexander Bicigo
Membre depuis le 14/02/2018
840 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S6-G3, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S6G3
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 34
