Introduction
By following this guide, you will be able to replace the CD Drive. The drive is probably the easiest part to replace on the laptop.
Pièces
Aucune pièce nécessaire.
Make sure the laptop is off and unplugged before starting.
  • Make sure the laptop is off and unplugged before starting.
  • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
Ajouter un commentaire
Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel. Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
Using the plastic opening tool, remove the back cover of the laptop. It is recommended that you start with a corner and run the tool throughout the edges of the cover.
  • Using the plastic opening tool, remove the back cover of the laptop.
  • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
  • Be sure not to bend the cover by applying too much force.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place. Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery.
  • Carefully disconnect the cable connecting the top of the battery and remove the battery.
The CD Drive is located at the bottom right area of the motherboard.
  • The CD Drive is located at the bottom right area of the motherboard.
Disconnect the CD drive from the motherboard connector on the left. Disconnect the CD drive from the motherboard connector on the left.
  • Disconnect the CD drive from the motherboard connector on the left.
Mohammad Gardezi
Membre depuis le 17/10/2017
649 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S13-G3, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 69
