Aller au contenu principal
HP Pavilion 15-cs3xxx Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-cs3xxx Battery Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 15-cs3xxx Battery Replacement, Battery: étape 1, image 2 de 2
    • Power off and unplug the laptop from any power source.
    • Flip the laptop over so the bottom is facing up.
    • Prior to removing the two screws near the hinge, remove the two rubber feet with a spudger or opening tool.
    • Two of the five screws are under the rubber feet nearest the hinges.
    • Use a Phillips screwdriver to remove the five screws on the underside of the laptop.
  2. HP Pavilion 15-cs3xxx Battery Replacement: étape 2, image 1 de 2 HP Pavilion 15-cs3xxx Battery Replacement: étape 2, image 2 de 2
    • Use an opening tool and picks to carefully pry off the back cover.
    • Work your way around the perimeter and release the clips holding the case to the device.
    • Remove the back case.
  3. HP Pavilion 15-cs3xxx Battery Replacement: étape 3, image 1 de 1
    • Use a screwdriver to remove the four screws holding the battery in place.
  4. HP Pavilion 15-cs3xxx Battery Replacement: étape 4, image 1 de 1
    • Remove the battery from the laptop.
Following these steps in reverse order to reassemble your device
Victoria Dobbs
Membre depuis le 05/28/23
130 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 33
30 derniers jours : 158
Total : 1,517
