Before starting, please turn off your laptop. Turn the HP Pavilion 17-f127ds over on a firm surface with the bottom facing up. Slide the battery lock latch, the latch on the left, inwards.
  • Before starting, please turn off your laptop.
  • Turn the HP Pavilion 17-f127ds over on a firm surface with the bottom facing up.
  • Slide the battery lock latch, the latch on the left, inwards.
  • Slide the battery release latch, the latch on the right, inwards to put it in the release position. This allows the battery to be removed.
    • Latch may be difficult and require extra force to slide.
  • Lift the battery up and remove it from computer.
Ajouter un commentaire
Flip your laptop over on a firm surface. Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
  • Flip your laptop over on a firm surface.
  • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
  • Flip your laptop back over.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop. With your fingers, disconnect the keyboard connector and the connector cable from the motherboard. Be careful not to lift the keyboard too high because it might rip off the connectors.
  • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
  • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
  • Be careful not to lift the keyboard too high because it might rip off the connectors.
  • Carefully remove the keyboard.
Disconnect the tape connecting the WLAN module to the main board. With a Phillips #0 screwdriver remove the remaining screw holding the speaker in place.
  • Disconnect the tape connecting the WLAN module to the main board.
  • With a Phillips #0 screwdriver remove the remaining screw holding the speaker in place.
Disconnect the speakers from the main board. Lift away the speakers, they are connected with a wire.
  • Disconnect the speakers from the main board.
  • Lift away the speakers, they are connected with a wire.
Stephen Brown
Membre depuis le 18/10/2017
201 Réputation
2 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G1, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 50
