Introduction
A broken fan can cause the device to overheat and run slow. In this guide, you will learn how to replace your HP Pavilion 17-g119dx laptop's fan. To perform the replacement, you will need a Phillips head screwdriver and a plastic opening tool to pop open the keyboard.
Ce dont vous avez besoin
Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
Two of these 6.5 mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
Outil utilisé dans cette étape :iFixit Opening Tool$1.99
Flip the computer back over with the screen facing up and open the laptop.
Use the Plastic Opening Tool to separate the face plate from the backing.
Outil utilisé dans cette étape :Phillips #00 Screwdriver$5.49
Unscrew the two 0.5 mm screws using a Phillips #00 screwdriver.
