Introduction
Remove and replace the RAM in your HP DV2160BR by following this guide. Be sure that the laptop is turned off when performing the removal and make sure to touch a metal object before working on the laptop.
Ce dont vous avez besoin
Start with the bottom of the laptop facing up.
Locate the panel that is covering the RAM compartment.
Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
Grab the RAM module and carefully pull it straight out of its slot.
Repeat this step for the second RAM module, which is located just underneath the first RAM module.
