Introduction
The Wi-Fi adapter is a crucial piece of hardware in your laptop, allowing access to the Internet via Wi-Fi connection. If you're having problems with connecting to the Wi-Fi, the wifi adapter could be the reason, so you could use this guide to remove and repair or replace the Wi-Fi adapter.
Pièces
Aucune pièce nécessaire.
Start with the bottom of the laptop facing up. Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
  • Start with the bottom of the laptop facing up.
  • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
Ajouter un commentaire
Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter. Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
Pull the 2 black wires with the gold pieces  out of the wifi adapter. The wifi adapter is now free to be removed.
  • Pull the 2 black wires with the gold pieces out of the wifi adapter.
  • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Shannon
Membre depuis le 11/04/2013
37 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-66, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 401
