Pièces
Aucune pièce nécessaire.
Press down and to the  right on the battery lock slide. Once slid over to the right the battery will pop up and out. Once slid over to the right the battery will pop up and out.
  • Press down and to the right on the battery lock slide.
  • Once slid over to the right the battery will pop up and out.
Ajouter un commentaire
Remove the seven screws from the back side of the laptop using a Philips Head screwdriver size PH1.
  • Remove the seven screws from the back side of the laptop using a Philips Head screwdriver size PH1.
Remove the seven screws from the battery compartment using a Philips Head screw driver size 0. Remove the seven screws from the battery compartment using a Philips Head screw driver size 0.
  • Remove the seven screws from the battery compartment using a Philips Head screw driver size 0.
Turn the computer around to the front side. Using the spudger tool prop open the key board casing. Using the spudger tool prop open the key board casing.
  • Turn the computer around to the front side.
  • Using the spudger tool prop open the key board casing.
Carefully lift up the key board. Then gently pull up the connecting wire clip to completely detach the keyboard. Then gently pull up the connecting wire clip to completely detach the keyboard.
  • Carefully lift up the key board.
  • Then gently pull up the connecting wire clip to completely detach the keyboard.
At the top right of the laptop there will be an another wire clip holding the keyboard casing. Carefully pull out the wire clip to fully detach the covering. Carefully pull out the wire clip to fully detach the covering.
  • At the top right of the laptop there will be an another wire clip holding the keyboard casing.
  • Carefully pull out the wire clip to fully detach the covering.
At the top right of the laptop remove the black wire from under the metal tabs using the tweezers. At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
Remove the black wire from the top right corner by gently pulling outward. Remove the black wire from the top right corner by gently pulling outward.
  • Remove the black wire from the top right corner by gently pulling outward.
At the top left of the computer remove the black clip using the spudger. Push the spudger to the right to pop out the clip.
  • At the top left of the computer remove the black clip using the spudger.
  • Push the spudger to the right to pop out the clip.
Locate at the bottom left of the computer a white clip. Using the spudger prop out the white clip. Using the spudger prop out the white clip.
  • Locate at the bottom left of the computer a white clip.
  • Using the spudger prop out the white clip.
On the left side of the computer locate the black wire with the clear clip. Gently pull the wire to the right to detach it.
  • On the left side of the computer locate the black wire with the clear clip.
  • Gently pull the wire to the right to detach it.
At the top corners of the computer, unscrew the 3 screws using a Philips Head screwdriver size 0. Lift up the top half of the computer carefully. Lift up the top half of the computer carefully.
  • At the top corners of the computer, unscrew the 3 screws using a Philips Head screwdriver size 0.
  • Lift up the top half of the computer carefully.
Locate the two screws at the bottom corners of the screen. Using the tweezers remove the rubber black covering over the screw. Using a Philips Head screwdriver size 0 remove the two screws.
  • Locate the two screws at the bottom corners of the screen.
  • Using the tweezers remove the rubber black covering over the screw.
  • Using a Philips Head screwdriver size 0 remove the two screws.
Using the spudger prop off the screen covering. Remove the covering to expose the screen completely. Remove the covering to expose the screen completely.
  • Using the spudger prop off the screen covering.
  • Remove the covering to expose the screen completely.
Remove the bottom two screen bearings. Using a Philips 1  screwdriver remove the two screws on each side. Using a Philips 1  screwdriver remove the two screws on each side.
  • Remove the bottom two screen bearings.
  • Using a Philips 1 screwdriver remove the two screws on each side.
Using the tweezers  remove the red and white wire  from the bottom of the screen. Using the tweezers  remove the red and white wire  from the bottom of the screen.
  • Using the tweezers remove the red and white wire from the bottom of the screen.
Prop the screen up slightly . Using the tweezers  unclip the white wire.
  • Prop the screen up slightly .
  • Using the tweezers unclip the white wire.
While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently. While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
  • While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
Remove the screen from the outer casing carefully.
  • Remove the screen from the outer casing carefully.
Locate RAM access door on the bottom side of the laptop.
  • Locate RAM access door on the bottom side of the laptop.
Locate the two screws holding down the RAM access door. Unscrew the two screws with a size #1 Phillips screwdriver. Unscrew the two screws with a size #1 Phillips screwdriver.
  • Locate the two screws holding down the RAM access door.
  • Unscrew the two screws with a size #1 Phillips screwdriver.
Lift up on the RAM cover and remove it to reveal RAM sticks. Lift up on the RAM cover and remove it to reveal RAM sticks.
  • Lift up on the RAM cover and remove it to reveal RAM sticks.
Gently pull apart the two metal tabs located on both sides of the stick of RAM. Gently pull apart the two metal tabs located on both sides of the stick of RAM.
  • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
Gently lift the RAM stick up and out of its seat.
  • Gently lift the RAM stick up and out of its seat.
Repeat the previous two steps for the remaining stick of RAM.
  • Repeat the previous two steps for the remaining stick of RAM.
With the battery and RAM removed, locate the hard drive access panel.
  • With the battery and RAM removed, locate the hard drive access panel.
Remove two 1.2 mm Philips#01 screws.
  • Remove two 1.2 mm Philips#01 screws.
After the screws are removed, slide the hard drive panel to right to remove it. After the screws are removed, slide the hard drive panel to right to remove it.
  • After the screws are removed, slide the hard drive panel to right to remove it.
Identify the three screws holding the hard drives cover in place. Remove each screw using a #0 Philips screwdriver to reveal the hard drive.
  • Identify the three screws holding the hard drives cover in place.
  • Remove each screw using a #0 Philips screwdriver to reveal the hard drive.
  • This particular laptop does not contain a hard drive-- yours will.
Locate the storage battery, next to the hard drive. Genlty pop out storage battery with fingers.
  • Locate the storage battery, next to the hard drive.
  • Genlty pop out storage battery with fingers.
Locate the Wifi card cover panel, left of the RAM. Using a Philips #1 screwdriver remove the screw holding the panel down.
  • Locate the Wifi card cover panel, left of the RAM.
  • Using a Philips #1 screwdriver remove the screw holding the panel down.
Lift up on the screw side to remove the panel. Lift up on the screw side to remove the panel.
  • Lift up on the screw side to remove the panel.
Remove two 1.2 mm Philips#01 screws. As the screws are removed the Wifi card will pop up.
  • As the screws are removed the Wifi card will pop up.
Remove Wifi card by pulling to the left of the laptop. Remove Wifi card by pulling to the left of the laptop.
  • Remove Wifi card by pulling to the left of the laptop.
Flip over to the top view
  • Flip over to the top view
  • Remove five 1.2 mm Philips#00 swrews
Using a spudger unclip the casing around all corners and edges. Using a spudger unclip the casing around all corners and edges.
  • Using a spudger unclip the casing around all corners and edges.
lift up the casing and remove to reveal the speakers. lift up the casing and remove to reveal the speakers.
  • lift up the casing and remove to reveal the speakers.
Remove highlighted 1.2 mm Philips #00 screw from right speaker.
  • Remove highlighted 1.2 mm Philips #00 screw from right speaker.
Using a spudger, remove the highlighted white wire. Using a spudger, remove the highlighted white wire.
  • Using a spudger, remove the highlighted white wire.
Using a spudger, remove both additional highlighted wires from the motherboad. Using a spudger, remove both additional highlighted wires from the motherboad. Using a spudger, remove both additional highlighted wires from the motherboad.
  • Using a spudger, remove both additional highlighted wires from the motherboad.
Lift up and out each speaker from the base. Lift up and out each speaker from the base. Lift up and out each speaker from the base.
  • Lift up and out each speaker from the base.
Zachary Herrera
Membre depuis le 20/03/2018
485 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G5, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G5, Covino Spring 2018
UMASSD-COVINO-S18S4G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 31
