Aller au contenu principal
HP Pavilion G7-2289wm Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion G7-2289wm Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Optical Drive Replacement, Optical Drive: étape 2, image 1 de 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Optical Drive Replacement: étape 3, image 1 de 2 HP Pavilion G7-2289wm Optical Drive Replacement: étape 3, image 2 de 2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
Ryson Smith
Membre depuis le 03/19/18
636 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G1, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 273
