Aller au contenu principal
HP Pavilion G7-2289wm Fan and Heat Sink Replacement
Ce dont vous avez besoin
  1. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Battery: étape 1, image 1 de 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Optical Drive: étape 2, image 1 de 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 3, image 1 de 2 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 3, image 2 de 2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
  4. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Hard Drive: étape 4, image 1 de 1
    • Pull the edge of the service cover toward you to remove it.
  5. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 5, image 1 de 1
    • Disconnect the hard drive connector cable from the motherboard.
  6. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 6, image 1 de 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
  7. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Keyboard: étape 7, image 1 de 1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  8. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 8, image 1 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 8, image 2 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 8, image 3 de 3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
  9. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Fan and Heat Sink: étape 9, image 1 de 1
    • Remove the three screws that hold the keyboard palm rest in place using a Phillips #0 screwdriver.
    • Lift the palm rest up and out.
  10. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 10, image 1 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 10, image 2 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 10, image 3 de 3
    • Remove the wires attached under the keyboard.
  11. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 11, image 1 de 1
    • Pry open the bottom of the laptop by using the opening tool to open it up. Do this around the entire outer edge of the laptop.
  12. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 12, image 1 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 12, image 2 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 12, image 3 de 3
    • Remove the screw that holds the motherboard in place.
    • Remove the wires attached to the motherboard.
    • Unplug the laptop fan.
  13. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: étape 13, image 1 de 1
    • Remove the four screws that hold the fan and heat sink in place.
    • Remove the entire heat sink from the laptop.
Clayton LaBrecque
Membre depuis le 03/19/18
171 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G1, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 17
Total : 422
