Introduction
If the keyboard on your laptop is malfunctioning, has numerous missing keys, or is broken, it will need to be replaced. Once a replacement is purchased, follow this guide to effectively replace it.
Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights. To remove this, pry it open with a spudger tool gently. It should pop out of place.
  • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
  • To remove this, pry it open with a spudger tool gently. It should pop out of place.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the three 6mm screws using a Phillips #1 screwdriver. Once the screws are removed, the keyboard is free from the base of the laptop.
  • Remove the three 6mm screws using a Phillips #1 screwdriver.
  • Once the screws are removed, the keyboard is free from the base of the laptop.
Disconnect the green ribbon cable using a plastic opening tool. Disconnect the green ribbon cable using a plastic opening tool.
  • Disconnect the green ribbon cable using a plastic opening tool.
Emily Hatstat
Membre depuis le 19/03/2018
481 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 15
