Aller au contenu principal
HP Pavilion Sleekbook 15-b000 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 2, image 1 de 1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 3, image 1 de 2 HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 3, image 2 de 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 4, image 1 de 1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement, Keyboard: étape 5, image 1 de 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 6, image 1 de 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 7, image 1 de 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 8, image 1 de 1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement, Case: étape 9, image 1 de 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 10, image 1 de 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 11, image 1 de 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 12, image 1 de 3 HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 12, image 2 de 3 HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 12, image 3 de 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement, Hard Drive: étape 13, image 1 de 1
    • Remove the 4 x 5.5 mm screws connecting the hard drive tot he case.
  14. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 14, image 1 de 1
    • Remove hard drive from bracket being careful of it's cable.
  15. HP Pavilion Sleekbook 15-b000 Hard Drive Replacement: étape 15, image 1 de 1
    • Disconnect cable from hard drive.
Sam Barkley
Membre depuis le 02/13/18
983 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S11-G2, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 625
