Introduction
The keyboard is one of the main components needed to interact with your laptop. This guide will show you how to replace your keyboard if you are having issues with typing on your laptop or to remove the keyboard for any further repairs to your laptop.
Pièces
Aucune pièce nécessaire.
Unplug laptop  from adapter and all other devices.
  • Unplug laptop from adapter and all other devices.
Ajouter un commentaire
Flip the laptop over with battery facing you.
  • Flip the laptop over with battery facing you.
Slide the battery lock on the right side open. Slide the Battery release latch on the left side.
  • Slide the battery lock on the right side open.
  • Slide the Battery release latch on the left side.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull battery out.
  • Pull battery out.
Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
Push screwdriver through screw hole top  pop the keyboard.
  • Push screwdriver through screw hole top pop the keyboard.
  • Make sure the screen is open.
Pry up the keyboard.
  • Pry up the keyboard.
  • The keyboard is still attached by it's ribbon.
Remove keyboard  wire  by popping latch under blue  plastic
  • Remove keyboard wire by popping latch under blue plastic
Sam Barkley
Membre depuis le 13/02/2018
959 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S11-G2, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 14
