Introduction
This guide will go through the steps to replace the screen if it is not displaying anything or the display is distorted.
Pièces
Aucune pièce nécessaire.
Unplug laptop  from adapter and all other devices.
  • Unplug laptop from adapter and all other devices.
Ajouter un commentaire
Flip the laptop over with battery facing you.
  • Flip the laptop over with battery facing you.
Slide the battery lock on the right side open. Slide the Battery release latch on the left side.
  • Slide the battery lock on the right side open.
  • Slide the Battery release latch on the left side.
Pull battery out.
  • Pull battery out.
Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
Push screwdriver through screw hole top  pop the keyboard.
  • Push screwdriver through screw hole top pop the keyboard.
  • Make sure the screen is open.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pry up the keyboard.
  • Pry up the keyboard.
  • The keyboard is still attached by it's ribbon.
Remove keyboard  wire  by popping latch under blue  plastic
  • Remove keyboard wire by popping latch under blue plastic
Using the spudger to lift up on the white  tabs
  • Using the spudger to lift up on the white tabs
  • Pull horizontally on the blue ribbon to disconnect the cables
Remove the five 5.5mm Phillips #1 screws from the case
  • Remove the five 5.5mm Phillips #1 screws from the case
Remove eight 6.5mm Phillips #1 screws from the back cover
  • Remove eight 6.5mm Phillips #1 screws from the back cover
Starting at a top corner, use the pry tool to split the case. Slowly work around the case, pulling up gently to release the clips. Slowly work around the case, pulling up gently to release the clips.
  • Starting at a top corner, use the pry tool to split the case.
  • Slowly work around the case, pulling up gently to release the clips.
Remove the four 5.5mm Phillips #1 screws attaching the screen.
  • Remove the four 5.5mm Phillips #1 screws attaching the screen.
Remove the two 3.5mm Phillips #1 screws from the bottom of the screen.
  • Remove the two 3.5mm Phillips #1 screws from the bottom of the screen.
Remove the screen from it's case.
  • Remove the screen from it's case.
  • Screen is still connected to it's case by a wire.
Lay the screen face down on a surface where it ill not scratch
  • Lay the screen face down on a surface where it ill not scratch
Lift up plastic over latch for the screen. Pull the connector away from the screen to disconnect  it.
  • Lift up plastic over latch for the screen.
  • Pull the connector away from the screen to disconnect it.
Sam Barkley
Membre depuis le 13/02/2018
959 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S11-G2, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 13
