Introduction
Memory, commonly known as RAM, is largely responsible for the speed of a computer, as it allows data to to be read and written. Improving your computers RAM may increase speed and allow your computer to run more programs simultaneously. The HP Pavilion TouchSmart 11z-e000 comes with 4gb of RAM. Typical RAM sizes range from 4gb-16gb. This laptop has one memory module slot which allows it to be upgraded to 8gb.
Pièces
Aucune pièce nécessaire.
Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
Ajouter un commentaire
Slide a spudger under the outer plastic cover of the laptop
  • Slide a spudger under the outer plastic cover of the laptop
  • Pull off the plastic cover of the laptop.
Push both tabs outward to release the memory module
  • Push both tabs outward to release the memory module
Grasp the memory module by the edge and pull gently to remove it
  • Grasp the memory module by the edge and pull gently to remove it
2 autre(s) ont terminé cette réparation.
Daniel
Membre depuis le 22/01/2015
143 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 21-22, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 6
Total : 568
