Introduction
Switching out the old CD drive to replace with a new one is relatively easy once the back cover of the laptop has been removed.
Ce dont vous avez besoin
Shut down the computer.
Disconnect all external devices and cables from the computer.
Locate the small panel below the panel you just removed.
Loosen the one screw in the middle with a #00 Phillips screwdriver. Again, the screw will not fall out of the panel when loosened.
Lift the panel up and out of its slot to remove.
Remove and set aside all of the highlighted screws in the first picture with a #00 Phillips screwdriver.
Remove and separately set aside all of the highlighted screws in the second picture with a #00 Phillips screwdriver.
2 autres ont terminé cette réparation.
