Aller au contenu principal
HP Pavilion dv1000 Media Keys Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv1000 Media Keys Replacement, Battery: étape 1, image 1 de 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Media Keys Replacement: étape 2, image 1 de 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Media Keys Replacement: étape 3, image 1 de 2 HP Pavilion dv1000 Media Keys Replacement: étape 3, image 2 de 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Media Keys Replacement: étape 4, image 1 de 3 HP Pavilion dv1000 Media Keys Replacement: étape 4, image 2 de 3 HP Pavilion dv1000 Media Keys Replacement: étape 4, image 3 de 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Media Keys Replacement, Keyboard: étape 5, image 1 de 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Media Keys Replacement: étape 6, image 1 de 2 HP Pavilion dv1000 Media Keys Replacement: étape 6, image 2 de 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion dv1000 Media Keys Replacement, Media Keys: étape 7, image 1 de 1
    • Turn the laptop upside-down again.
  8. HP Pavilion dv1000 Media Keys Replacement: étape 8, image 1 de 2 HP Pavilion dv1000 Media Keys Replacement: étape 8, image 2 de 2
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
Tyler Latour
Membre depuis le 03/12/14
266 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 Membre de l'équipe UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G7
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 13
Total : 654
