Aller au contenu principal
HP Pavilion dv5000 RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv5000 RAM Replacement, Battery: étape 1, image 1 de 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 RAM Replacement, RAM Cover: étape 2, image 1 de 3 HP Pavilion dv5000 RAM Replacement, RAM Cover: étape 2, image 2 de 3 HP Pavilion dv5000 RAM Replacement, RAM Cover: étape 2, image 3 de 3
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 RAM Replacement, RAM: étape 3, image 1 de 1
    • Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
    • There are two RAM cards in this device.
  4. HP Pavilion dv5000 RAM Replacement: étape 4, image 1 de 3 HP Pavilion dv5000 RAM Replacement: étape 4, image 2 de 3 HP Pavilion dv5000 RAM Replacement: étape 4, image 3 de 3
    • Remove the RAM.
  5. HP Pavilion dv5000 RAM Replacement: étape 5, image 1 de 1
    • As in step 3, press the clips on both sides to release the second RAM clip.
  6. HP Pavilion dv5000 RAM Replacement: étape 6, image 1 de 3 HP Pavilion dv5000 RAM Replacement: étape 6, image 2 de 3 HP Pavilion dv5000 RAM Replacement: étape 6, image 3 de 3
    • Remove the RAM.
2 autres ont terminé cette réparation.
Thanh Nguyen
Membre depuis le 10/05/10
399 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 21-34, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 15,022
