Aller au contenu principal
HP Pavilion dv7-3065dx RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv7-3065dx RAM Replacement, Battery: étape 1, image 1 de 2 HP Pavilion dv7-3065dx RAM Replacement, Battery: étape 1, image 2 de 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx RAM Replacement: étape 2, image 1 de 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx RAM Replacement: étape 3, image 1 de 2 HP Pavilion dv7-3065dx RAM Replacement: étape 3, image 2 de 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx RAM Replacement, RAM: étape 4, image 1 de 1
    • Remove the four circled screws using a #1 philips head screwdriver
    • Note: Be sure to leave the screws in the pannel
    • Pry off cover and place to the side.
  5. HP Pavilion dv7-3065dx RAM Replacement: étape 5, image 1 de 1
    • The RAM modules will be found on the right side of the access panel
    • CAUTION - The RAM modules are sensitive to electrostatic discharge. It is recommended to wear an anti static bracelet while handling the RAM.
  6. HP Pavilion dv7-3065dx RAM Replacement: étape 6, image 1 de 2 HP Pavilion dv7-3065dx RAM Replacement: étape 6, image 2 de 2
    • To remove RAM modules, pry metal tabs out of the modules, and pull ram out (Starting from the top RAM module).
    • Note: The RAM Modules pop out away from the motherboard. In order to replace them, slot the gold plated end into the terminal and push down towards the motherboard.
3 autres ont terminé cette réparation.
Jonathan Winkler
Membre depuis le 02/06/17
161 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-5, Wilder Spring 2017 Membre de l'équipe Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 16
Total : 1,262
