Introduction
This is a RAM replacement for HP Pavilion dv7t-7000.
Pièces
Aucune pièce nécessaire.
Turn the computer off and disconnect if from all power sources.
  • Turn the computer off and disconnect if from all power sources.
Ajouter un commentaire
Slide the battery release switch to the left.
  • Slide the battery release switch to the left.
Hold the release switch all of the way to the left and your other hand to pull the battery out.
  • Hold the release switch all of the way to the left and your other hand to pull the battery out.
Unscrew the single Phillips #00 screw.
  • Unscrew the single Phillips #00 screw.
  • Screw will not come out, it is connected to the panel
Remove service hatch by sliding away from the computer and lifting up. Remove service hatch by sliding away from the computer and lifting up.
  • Remove service hatch by sliding away from the computer and lifting up.
Push the retraining springs away from the RAM at the same time to unlock the RAM. Push the retraining springs away from the RAM at the same time to unlock the RAM.
  • Push the retraining springs away from the RAM at the same time to unlock the RAM.
Pull the RAM out. Follow the same procedure for the additional RAM.
  • Pull the RAM out.
  • Follow the same procedure for the additional RAM.
Afnan
Membre depuis le 21/02/2018
289 Réputation
3 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 42
