Aller au contenu principal
HP Pavilion dv7t-7000 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Battery: étape 1, image 1 de 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Back Panel: étape 4, image 1 de 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: étape 5, image 1 de 2 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: étape 5, image 2 de 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 1 de 2 HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 2 de 2
    • Use the flat end of a spudger to pop off the antenna connectors.
  7. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: étape 7, image 1 de 3 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: étape 7, image 2 de 3 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: étape 7, image 3 de 3
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
Eric Easley
Membre depuis le 02/10/18
251 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 172
