Introduction
The motherboard is the meat of your device. Almost everything on the inside such as the fan, mouse pad, and speakers, are all attached. Although the removal and replacement of this component is not difficult, it should be done cautiously.
Slide pill shaped tab to the other side of the channel.
  • Slide pill shaped tab to the other side of the channel.
Ajouter un commentaire
  • Remove battery while keeping the tab to the side.
Unscrew the two screws JIS #0 located on opposites sides of the panel.
  • Unscrew the two screws JIS #0 located on opposites sides of the panel.
  • Screws are attached to the panel and will not fully come out.
Carefully pry off the L-shaped panel.
  • Carefully pry off the L-shaped panel.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Pull out and unplug the tab on the right hand side.
  • Pull out and unplug the tab on the right hand side.
Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
Remove 3 screws located where the battery previously was.
  • Remove 3 screws located where the battery previously was.
Remove 6 screws located under the spot where the smaller L-shaped panel was located. Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
Slowly pry off the keyboard from the back panel.
  • Slowly pry off the keyboard from the back panel.
  • Between the back panel and the keyboard there are two ribbon wires.
  • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
Unplug wires connecting back panel to keyboard.
  • Unplug wires connecting back panel to keyboard.
In lower left hand corner, pull on black tab to unplug the disc drive. In lower left hand corner, pull on black tab to unplug the disc drive.
  • In lower left hand corner, pull on black tab to unplug the disc drive.
In upper left hand corner, unplug the large black electrical tape covered laptop plug. In upper left hand corner, unplug the large black electrical tape covered laptop plug.
  • In upper left hand corner, unplug the large black electrical tape covered laptop plug.
Robert Hamilton
Membre depuis le 01/03/2018
1 051 Réputation
10 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G7, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G7
4 membres
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 39
