Introduction
This guide shows how to take apart the HP Pavilion X2 laptop to expose the SSD card to replace it with a new one.
Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly. Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly. Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
Ajouter un commentaire
Gently lift and remove the display panel from the assembly. Gently lift and remove the display panel from the assembly.
  • Gently lift and remove the display panel from the assembly.
Remove the tape that covers the battery connector on the system board and carefully disconnect the battery cable from its connector on the system board. Remove the tape that covers the battery connector on the system board and carefully disconnect the battery cable from its connector on the system board. Remove the tape that covers the battery connector on the system board and carefully disconnect the battery cable from its connector on the system board.
  • Remove the tape that covers the battery connector on the system board and carefully disconnect the battery cable from its connector on the system board.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully disconnect the white ribbon cable from the system board. Carefully disconnect the white ribbon cable from the system board. Carefully disconnect the white ribbon cable from the system board.
  • Carefully disconnect the white ribbon cable from the system board.
Using the Phillips #0 screwdriver, carefully remove the 4 corner screws  that hold the battery to the display panel. 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length. Remove the battery from the device.
  • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
  • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
  • Remove the battery from the device.
How do you replace those magnets that help snap the laptop's into place?
Alfa Orellana - Réponse
To unscrew the SSD card use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws To unscrew the SSD card use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws To unscrew the SSD card use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
  • To unscrew the SSD card use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
Remove the SSD card. Remove the SSD card. Remove the SSD card.
  • Remove the SSD card.
2 autre(s) ont terminé cette réparation.
David Zambrano
Membre depuis le 28/09/2017
597 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G4, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 membres
5 tutoriels rédigés
Is this about the WiFi card? Because I cant see the SSD in any of your pictures.
Julian Lemmerich - Réponse
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 68
30 derniers jours : 360
Total : 1,189
