Aller au contenu principal
HP Pavilion x2 10-n113dx Screen Replacement
Ce dont vous avez besoin
  1. HP Pavilion x2 10-n113dx Screen Replacement, Battery: étape 1, image 1 de 3 HP Pavilion x2 10-n113dx Screen Replacement, Battery: étape 1, image 2 de 3 HP Pavilion x2 10-n113dx Screen Replacement, Battery: étape 1, image 3 de 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Screen Replacement: étape 2, image 1 de 2 HP Pavilion x2 10-n113dx Screen Replacement: étape 2, image 2 de 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Screen Replacement: étape 3, image 1 de 3 HP Pavilion x2 10-n113dx Screen Replacement: étape 3, image 2 de 3 HP Pavilion x2 10-n113dx Screen Replacement: étape 3, image 3 de 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Screen Replacement: étape 4, image 1 de 3 HP Pavilion x2 10-n113dx Screen Replacement: étape 4, image 2 de 3 HP Pavilion x2 10-n113dx Screen Replacement: étape 4, image 3 de 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Screen Replacement: étape 5, image 1 de 3 HP Pavilion x2 10-n113dx Screen Replacement: étape 5, image 2 de 3 HP Pavilion x2 10-n113dx Screen Replacement: étape 5, image 3 de 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx Screen Replacement, Screen: étape 6, image 1 de 3 HP Pavilion x2 10-n113dx Screen Replacement, Screen: étape 6, image 2 de 3 HP Pavilion x2 10-n113dx Screen Replacement, Screen: étape 6, image 3 de 3
    • Using the Phillips #0 screwdriver, carefully remove the 21 screws that hold the screen to the display panel. 3.32 mm head, 3.99 mm length (RED) , 2.82 head 3.5 mm length (YELLOW), and 4.15 mm head, 2.35 mm length (BLUE).
    • 3.32 mm head, 3.99 mm length.
    • 2.82 head 3.5 mm length.
    • 4.15 mm head, 2.35 mm length.
  7. HP Pavilion x2 10-n113dx Screen Replacement: étape 7, image 1 de 3 HP Pavilion x2 10-n113dx Screen Replacement: étape 7, image 2 de 3 HP Pavilion x2 10-n113dx Screen Replacement: étape 7, image 3 de 3
    • Very carefully lift the circuit board in order to keep everything attached. Be careful with any cables that may still be connected.
5 autres ont terminé cette réparation.
David Zambrano
Membre depuis le 09/28/17
822 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G4, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 membres
5 tutoriels rédigés
4 commentaires
where can i get the replacement screen for this model
Umer Muhammad Anwar - Réponse
where can i get the replacement screen for this model?
Olumuyiwa Oyenuche - Réponse
This guide is bad. He takes the same screws out twice. There is more than 21 screws. Do not follow this guide you will end up breaking something.
matthewcomley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 20
Total : 6,011
