Aller au contenu principal
HP Pavilion zd8000 CD/Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion zd8000 CD/Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 CD/Optical Drive Replacement: étape 2, image 1 de 2 HP Pavilion zd8000 CD/Optical Drive Replacement: étape 2, image 2 de 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 CD/Optical Drive Replacement, CD/Optical Drive: étape 3, image 1 de 1
    • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
  4. HP Pavilion zd8000 CD/Optical Drive Replacement: étape 4, image 1 de 2 HP Pavilion zd8000 CD/Optical Drive Replacement: étape 4, image 2 de 2
    • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
    • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
  5. HP Pavilion zd8000 CD/Optical Drive Replacement: étape 5, image 1 de 2 HP Pavilion zd8000 CD/Optical Drive Replacement: étape 5, image 2 de 2
    • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
Allie Menard
Membre depuis le 04/12/11
820 Réputation
13 tutoriels rédigés
Équipe
Cal Poly, Team 24-56, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 12
Total : 3,429
