Introduction
Replacing the ink cartridge is easy and requires no technical skill or tools.
Required Tools
  • None
In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
  • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
  • There are two pieces to the mouth, make sure to pull down both.
Ajouter un commentaire
Press down on the head of the ink cartridge that needs replacing.  This will release the cartridge and allow you to pull it out. Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
  • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
Place the new cartridge into the slot and press firmly until it pops into place.
  • Place the new cartridge into the slot and press firmly until it pops into place.
2 autre(s) ont terminé cette réparation.
Tim Wise
Membre depuis le 01/04/2011
170 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 10-38, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 membres
10 tutoriels rédigés
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - Réponse
the HP ink cartridge is 60. Does that make any difference???
April -
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 33
Total : 9,917
