Lift the top cover of the scanner. Using a small plastic prying tool, carefully pry the plastic frame surrounding the glass from the printer hood. Pry the side piece from the printer hood.
  • Lift the top cover of the scanner.
  • Using a small plastic prying tool, carefully pry the plastic frame surrounding the glass from the printer hood.
  • Pry the side piece from the printer hood.
  • Pull the frame out.
Ajouter un commentaire
Using a T10 screwdriver, unscrew the two screws that fasten the frame to the printer hood.
  • Using a T10 screwdriver, unscrew the two screws that fasten the frame to the printer hood.
Pushing the clip behind the cover piece in, pull the cover piece outwards. Pushing the clip behind the cover piece in, pull the cover piece outwards.
  • Pushing the clip behind the cover piece in, pull the cover piece outwards.
There are two screws under where the power button panel was and across the printer slider. Unscrew them with a T10 screwdriver. There are two screws under where the power button panel was and across the printer slider. Unscrew them with a T10 screwdriver.
  • There are two screws under where the power button panel was and across the printer slider. Unscrew them with a T10 screwdriver.
Pull the printed circuit board from the main printer body.
  • Pull the printed circuit board from the main printer body.
  • Unplug the small ribbon cable from the circuit board.
Pull the memory card reader's circuit board out of its slot. Detach the wire harness.
  • Pull the memory card reader's circuit board out of its slot.
  • Detach the wire harness.
Press the clip directly behind the TouchSmart panel. Pull the clip to detach.
  • Press the clip directly behind the TouchSmart panel.
  • Pull the clip to detach.
  • Disconnect the ribbon cable from the TouchSmart panel to detach from the main printer body.
  • Do not hesitate to use force to remove the TouchSmart panel.
Gripping the printer hood, pull upward.
  • Gripping the printer hood, pull upward.
Lift the scanning lid from the lower portion of the printer hood. Lift the scanning lid from the lower portion of the printer hood.
  • Lift the scanning lid from the lower portion of the printer hood.
Remove torx screw on bottom of assembly in corner near touchsmart screen space.
Jeff - Réponse
Leaving the ribbon connected, lift the sliding scanner off the track. Pull the ribbon cable out of the slot on the scanner circuit board.
  • Leaving the ribbon connected, lift the sliding scanner off the track.
  • Pull the ribbon cable out of the slot on the scanner circuit board.
  • Insert the scanning piece into the rolling track.
To reassemble the sliding scan piece, follow these instructions in reverse order.
Renee Lamb
Membre depuis le 26/09/2012
208 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 2-11, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 membres
6 tutoriels rédigés
Where can i buy the scaning piece? Im from Spain.
Bogdan Cosmin - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 1,193
