Aller au contenu principal
HP ProBook 4320t RAM Replacement Guide
Ce dont vous avez besoin
  1. HP ProBook 4320t RAM Replacement Guide, Battery Removal: étape 1, image 1 de 2 HP ProBook 4320t RAM Replacement Guide, Battery Removal: étape 1, image 2 de 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t RAM Replacement Guide, Screws: étape 2, image 1 de 2 HP ProBook 4320t RAM Replacement Guide, Screws: étape 2, image 2 de 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t RAM Replacement Guide, Flip: étape 3, image 1 de 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t RAM Replacement Guide, Push N Lift: étape 4, image 1 de 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t RAM Replacement Guide, Unscrewing: étape 5, image 1 de 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t RAM Replacement Guide, Careful Now: étape 6, image 1 de 2 HP ProBook 4320t RAM Replacement Guide, Careful Now: étape 6, image 2 de 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t RAM Replacement Guide, Disconnect Wire: étape 7, image 1 de 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t RAM Replacement Guide, RAM: étape 8, image 1 de 1
    • Press the two prongs outward, and the RAM card will come out of PCI Express connector.
5 autres ont terminé cette réparation.
Eric Markham
Membre depuis le 08/29/14
227 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 9-5, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 10
Total : 1,109
