Aller au contenu principal
HP ProBook 4320t Touchpad Replacement Guide
Ce dont vous avez besoin
  1. HP ProBook 4320t Touchpad Replacement Guide, Battery Removal: étape 1, image 1 de 2 HP ProBook 4320t Touchpad Replacement Guide, Battery Removal: étape 1, image 2 de 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Touchpad Replacement Guide, Screws: étape 2, image 1 de 2 HP ProBook 4320t Touchpad Replacement Guide, Screws: étape 2, image 2 de 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Touchpad Replacement Guide, Flip: étape 3, image 1 de 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Touchpad Replacement Guide, Push N Lift: étape 4, image 1 de 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Touchpad Replacement Guide, Unscrewing: étape 5, image 1 de 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Touchpad Replacement Guide, Careful Now: étape 6, image 1 de 2 HP ProBook 4320t Touchpad Replacement Guide, Careful Now: étape 6, image 2 de 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Touchpad Replacement Guide, Disconnect Wire: étape 7, image 1 de 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Touchpad Replacement Guide, Unscrew: étape 8, image 1 de 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Touchpad Replacement Guide, Slide the Panel Off: étape 9, image 1 de 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Touchpad Replacement Guide, Lift up Carefully: étape 10, image 1 de 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Touchpad Replacement Guide, Disconnect Wire: étape 11, image 1 de 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Touchpad Replacement Guide, Unscrewing: étape 12, image 1 de 1
    • Unscrew the two (2.5 mm Phillips) screws on the touch pad retention panel (Use Phillips #0 screw driver).
  13. HP ProBook 4320t Touchpad Replacement Guide, Remove Retention Panel: étape 13, image 1 de 1
    • Slightly push the touch pad retention panel forward to remove from clasp and lift up.
  14. HP ProBook 4320t Touchpad Replacement Guide, Touch Pad Screws: étape 14, image 1 de 1
    • Unscrew the following two (2.0 mm Phillips) screws attached to the touchpad (Use Phillips #0 screw driver).
  15. HP ProBook 4320t Touchpad Replacement Guide, Remove Touchpad: étape 15, image 1 de 1
    • Slightly lift up the bottom of the touchpad and pull towards you to free the touchpad from the casing
3 autres ont terminé cette réparation.
Joshua
Membre depuis le 09/23/14
134 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 9-5, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,301
