Introduction
If your battery is not working, needs to cool down, or needs to be taken out for another reason, follow the steps below to remove it properly.
Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
  • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
  • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Slide the two battery release latches towards the center of the laptop to release the battery.
  • Slide the two battery release latches towards the center of the laptop to release the battery.
Tilt the battery upward. Remove it from the laptop.
  • Tilt the battery upward.
  • Remove it from the laptop.
Jennifer Sexton
Membre depuis le 18/03/2018
531 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S5-G1, Williams Spring 2018 Membre de l'équipe Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 19
Total : 42
