Aller au contenu principal
HP Spectre x360 13t-4000 Battery Replacement
Ce dont vous avez besoin
  1. HP Spectre x360 13t-4000 Battery Replacement, Bottom Cover: étape 1, image 1 de 2 HP Spectre x360 13t-4000 Battery Replacement, Bottom Cover: étape 1, image 2 de 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Battery Replacement: étape 2, image 1 de 2 HP Spectre x360 13t-4000 Battery Replacement: étape 2, image 2 de 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Battery Replacement: étape 3, image 1 de 3 HP Spectre x360 13t-4000 Battery Replacement: étape 3, image 2 de 3 HP Spectre x360 13t-4000 Battery Replacement: étape 3, image 3 de 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Battery Replacement, Battery: étape 4, image 1 de 3 HP Spectre x360 13t-4000 Battery Replacement, Battery: étape 4, image 2 de 3 HP Spectre x360 13t-4000 Battery Replacement, Battery: étape 4, image 3 de 3
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
4 autres ont terminé cette réparation.
Brandon Carvalho
Membre depuis le 03/21/19
566 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G4, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 28
Total : 11,553
