Aller au contenu principal
HP iPAQ H2200 motherbaord replacement
Ce dont vous avez besoin
  1. HP iPAQ H2200 motherbaord replacement, Battery: étape 1, image 1 de 1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 motherbaord replacement: étape 2, image 1 de 2 HP iPAQ H2200 motherbaord replacement: étape 2, image 2 de 2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 motherbaord replacement, Main Board: étape 3, image 1 de 1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 motherbaord replacement: étape 4, image 1 de 1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 motherbaord replacement: étape 5, image 1 de 1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 motherbaord replacement: étape 6, image 1 de 3 HP iPAQ H2200 motherbaord replacement: étape 6, image 2 de 3 HP iPAQ H2200 motherbaord replacement: étape 6, image 3 de 3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 motherbaord replacement: étape 7, image 1 de 2 HP iPAQ H2200 motherbaord replacement: étape 7, image 2 de 2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 motherbaord replacement: étape 8, image 1 de 1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 motherbaord replacement: étape 9, image 1 de 1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 motherbaord replacement: étape 10, image 1 de 1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 motherbaord replacement: étape 11, image 1 de 1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
4 autres ont terminé cette réparation.
Tyler Andrews
Membre depuis le 01/13/10
209 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-12, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 4,616
