Aller au contenu principal
HP iPAQ HW6515 Flash LED Bulb Replacement
Ce dont vous avez besoin
  1. HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: étape 1, image 1 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: étape 1, image 2 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: étape 1, image 3 de 3
    • Flip the HP iPAQ HW6515 over with the screen facing down.
    • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
    • Place the back of the case aside for now.
  2. HP iPAQ HW6515 Flash LED Bulb Replacement: étape 2, image 1 de 1
    • Remove the battery by pulling up on the black tab.
  3. HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: étape 3, image 1 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: étape 3, image 2 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: étape 3, image 3 de 3
    • Unscrew the four screws using the T6 hexagonal star screwdriver.
    • Unscrew the middle screw using the Phillips 00 screwdriver.
    • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
  4. HP iPAQ HW6515 Flash LED Bulb Replacement: étape 4, image 1 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement: étape 4, image 2 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement: étape 4, image 3 de 3
    • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
    • Slide the plastic opening tool along the seam until the two halves of the case separate.
  5. HP iPAQ HW6515 Flash LED Bulb Replacement: étape 5, image 1 de 2 HP iPAQ HW6515 Flash LED Bulb Replacement: étape 5, image 2 de 2
    • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
  6. HP iPAQ HW6515 Flash LED Bulb Replacement: étape 6, image 1 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement: étape 6, image 2 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement: étape 6, image 3 de 3
    • Gently pull off the black rubber square covering the LED light.
    • The LED is now exposed.
    • Wedge the plastic opening tool under the LED to pop it out and expose its wire.
    • Using your index finger and thumb, unplug the wire from the phone and remove the LED.
Steven Vo
Membre depuis le 04/02/12
33 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-17, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 15-17, Forte Spring 2012
CPSU-FORTE-S12S15G17
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,148
