Aller au contenu principal
HP iPAQ HW6515 Motherboard Replacement
Ce dont vous avez besoin
  1. HP iPAQ HW6515 Motherboard Replacement, Battery: étape 1, image 1 de 3 HP iPAQ HW6515 Motherboard Replacement, Battery: étape 1, image 2 de 3 HP iPAQ HW6515 Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Flip the HP iPAQ HW6515 over with the screen facing down.
    • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
    • Place the back of the case aside for now.
  2. HP iPAQ HW6515 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the battery by pulling up on the black tab.
  3. HP iPAQ HW6515 Motherboard Replacement, Motherboard: étape 3, image 1 de 3 HP iPAQ HW6515 Motherboard Replacement, Motherboard: étape 3, image 2 de 3 HP iPAQ HW6515 Motherboard Replacement, Motherboard: étape 3, image 3 de 3
    • Unscrew the four outside screws using the T6 hexagonal star screwdriver.
    • Unscrew the inside middle screw using a Phillips 00 screwdriver.
    • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
  4. HP iPAQ HW6515 Motherboard Replacement: étape 4, image 1 de 3 HP iPAQ HW6515 Motherboard Replacement: étape 4, image 2 de 3 HP iPAQ HW6515 Motherboard Replacement: étape 4, image 3 de 3
    • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
    • Slide the plastic opening tool along the seam until the two halves of the case separate.
  5. HP iPAQ HW6515 Motherboard Replacement: étape 5, image 1 de 3 HP iPAQ HW6515 Motherboard Replacement: étape 5, image 2 de 3 HP iPAQ HW6515 Motherboard Replacement: étape 5, image 3 de 3
    • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
  6. HP iPAQ HW6515 Motherboard Replacement: étape 6, image 1 de 1
    • Use a 00 Phillips screwdriver to remove the three small screws holding down the motherboard.
  7. HP iPAQ HW6515 Motherboard Replacement: étape 7, image 1 de 1
    • Peel back the black tape that covers the connector.
    • It is fine if one of the left connectors comes off along with the tape.
  8. HP iPAQ HW6515 Motherboard Replacement: étape 8, image 1 de 3 HP iPAQ HW6515 Motherboard Replacement: étape 8, image 2 de 3 HP iPAQ HW6515 Motherboard Replacement: étape 8, image 3 de 3
    • Lift the black tab to a 45 degree angle.
    • Use a screwdriver to get under the tape and disconnect the tape from the black tab.
  9. HP iPAQ HW6515 Motherboard Replacement: étape 9, image 1 de 2 HP iPAQ HW6515 Motherboard Replacement: étape 9, image 2 de 2
    • Gently pry the motherboard out of the front casing, bottom first.
    • Disconnect the wire connecting the motherboard to the front casing. Using too much force will damage this wire.
Ashley Schaefer
Membre depuis le 04/04/12
83 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-17, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 15-17, Forte Spring 2012
CPSU-FORTE-S12S15G17
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 1,237
