Here is the Desire X, with the touchscreen damaged, but working. I have tried to replace only the touch, but I broke the LCD... It´s very very hard to separate...
  • Here is the Desire X, with the touchscreen damaged, but working. I have tried to replace only the touch, but I broke the LCD... It´s very very hard to separate...
Ajouter un commentaire
Once the back cover and battery are removed, its time to dissasembly. First unscrew the 5 torx #5 from back side. Then, with a flat screwdriver, push and open the back cover, from side to side. Then, with a flat screwdriver, push and open the back cover, from side to side.
  • Once the back cover and battery are removed, its time to dissasembly. First unscrew the 5 torx #5 from back side.
  • Then, with a flat screwdriver, push and open the back cover, from side to side.
Now, on the main board, we have to remove the screw near the camera. Release the connector on the bottom Finally, remove the antenna connector.
  • Now, on the main board, we have to remove the screw near the camera.
  • Release the connector on the bottom
  • Finally, remove the antenna connector.
Once the bottom connector is loosed, you can take away the sound board and separate the flat cable from underneath. Next, the power button has to be removed. It is a bit sticky, so you may want to use a cutter or knife to separate. Long nails also work.
  • Once the bottom connector is loosed, you can take away the sound board and separate the flat cable from underneath.
  • Next, the power button has to be removed. It is a bit sticky, so you may want to use a cutter or knife to separate. Long nails also work.
Now, its time to release the vibrator connector (or vibrator from holder - easier), and then release the lower connector on the main board ( see pic 2). Remove the black tape first, and then use some tweezers to pull out the connector. Once its done, lift by one side the main board, and you can see the LCD connector. Open the white tab by lifting it up at the edge, and remove the flat cable. Once its done, lift by one side the main board, and you can see the LCD connector. Open the white tab by lifting it up at the edge, and remove the flat cable.
  • Now, its time to release the vibrator connector (or vibrator from holder - easier), and then release the lower connector on the main board ( see pic 2). Remove the black tape first, and then use some tweezers to pull out the connector.
  • Once its done, lift by one side the main board, and you can see the LCD connector. Open the white tab by lifting it up at the edge, and remove the flat cable.
It will be quite easy after you lift the white piece (blocking the pins&cable) in vertical position
irmalangus - Réponse
Jamie, thanks! It works :)
Now, its time to remove the product label, and keep it without bend to put back togheter. Then, under the silver ribbon, which is hard to remove, there is another flat connector, which must be disconnected. Then, under the silver ribbon, which is hard to remove, there is another flat connector, which must be disconnected.
  • Now, its time to remove the product label, and keep it without bend to put back togheter.
  • Then, under the silver ribbon, which is hard to remove, there is another flat connector, which must be disconnected.
The flat cable that goes to main board must be removed, and the flat cable of the touch is loosed. Remove the speaker from the top side of the phone.
  • The flat cable that goes to main board must be removed, and the flat cable of the touch is loosed.
  • Remove the speaker from the top side of the phone.
To remove the glue from the LCD and touch of the screen, we have to heat all the screen, with special attention to the top and bottom zones. I have one Hot Air Station, but you can do it with a hairdryer. With more time you heat, more easy to remove, but be careful... With a Metal thin blade, insert between bezel and LCD, and bend it to start releasing.
  • To remove the glue from the LCD and touch of the screen, we have to heat all the screen, with special attention to the top and bottom zones. I have one Hot Air Station, but you can do it with a hairdryer. With more time you heat, more easy to remove, but be careful...
  • With a Metal thin blade, insert between bezel and LCD, and bend it to start releasing.
Finally, the both parts comes apart. At the left, the LCD + touch. At the right, the chassis.
  • Finally, the both parts comes apart. At the left, the LCD + touch. At the right, the chassis.
  • Now, to assembly the unit back togheter, follow the steps backwards.
12 autre(s) ont terminé cette réparation.
Jaime
Membre depuis le 05/11/2013
3 106 Réputation
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 39
Total : 20,734
