Introduction
With this phone, the LCD and digitizer are removed together. These can then be separated by heating. If there is a discrepancy with the way images appear on your screen you may have a broken LCD. However, if you are unable to utilize the touchscreen interface then you may have a broken digitizer.
Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
  • Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
Ajouter un commentaire
Remove the battery after taking off the cover.
  • Remove the battery after taking off the cover.
Remove eight 4mm and one 5mm Torx screws.
  • Remove eight 4mm and one 5mm Torx screws.
This should be Step 3.
Tisha - Réponse
Use a prying tool to pry off the midframe. Use a prying tool to pry off the midframe.
  • Use a prying tool to pry off the midframe.
This should be Step 4.
Tisha - Réponse
Remove the 4mm Torx screw holding the charging port to the phone.
  • Remove the 4mm Torx screw holding the charging port to the phone.
This should be Step 5.
Tisha - Réponse
Remove the silver bracket holding the charging port in place.
  • Remove the silver bracket holding the charging port in place.
This should be Step 6.
Tisha - Réponse
Use a prying tool to remove the charging port as shown.
  • Use a prying tool to remove the charging port as shown.
This should be Step 7.
Tisha - Réponse
Pry off and remove the back cover Pry off and remove the back cover Pry off and remove the back cover
  • Pry off and remove the back cover
Remove the 4mm Torx screw.
  • Remove the 4mm Torx screw.
Remove tabs holding the motherboard to the phone. Remove tabs holding the motherboard to the phone. Remove tabs holding the motherboard to the phone.
  • Remove tabs holding the motherboard to the phone.
4 autre(s) ont terminé cette réparation.
Tevin
Membre depuis le 24/09/2014
639 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 15-1, Remmell Fall 2014 Membre de l'équipe USF Tampa, Team 15-1, Remmell Fall 2014
USFT-REMMELL-F14S15G1
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 760
