Tools Needed: 1. Safety pry tool (guitar pick), 2. Tweezers, 3. Phillips Screwdriver, 4. Star tip Precision Screwdriver, 5. Flathead Screwdriver
  • Tools Needed: 1. Safety pry tool (guitar pick), 2. Tweezers, 3. Phillips Screwdriver, 4. Star tip Precision Screwdriver, 5. Flathead Screwdriver
Ajouter un commentaire
Use your safety pry tool on the outside edges of the back casing to lift and remove it Use your safety pry tool on the outside edges of the back casing to lift and remove it Use your safety pry tool on the outside edges of the back casing to lift and remove it
  • Use your safety pry tool on the outside edges of the back casing to lift and remove it
Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off
  • Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off
Remove old lens. Place replacement lens over the camera lens and it should loosely snap on
  • Remove old lens.
  • Place replacement lens over the camera lens and it should loosely snap on
  • Info*: Don’t worry if the cover is loose because the cover of the phone would hold it in place
Snap the cover back into place
  • Snap the cover back into place
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
Victoria
Membre depuis le 23/10/2014
94 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-4, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 5-4, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G4
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 254
