Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
  • Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
Ajouter un commentaire
Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
  • Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
When open, pull on “Open” tab and  it should rotate towards you Grab the bottom edge of the battery and pull it toward you
  • When open, pull on “Open” tab and it should rotate towards you
  • Grab the bottom edge of the battery and pull it toward you
On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it Info*: The adhesive tape that you may find will not be necessary for replacement later
  • On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it
  • Info*: The adhesive tape that you may find will not be necessary for replacement later
Remove the two Phillips screws to release the casing above the port Remove the top and bottom pairs of Torx screws.
  • Remove the two Phillips screws to release the casing above the port
  • Remove the top and bottom pairs of Torx screws.
  • Remove the middle pair of two Phillips screws.
To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
  • To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
  • Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
Remove the rear housing by prying around the edge with your Safety Pry Tool Remove the rear housing by prying around the edge with your Safety Pry Tool
  • Remove the rear housing by prying around the edge with your Safety Pry Tool
Unplug the wire connecting the vibrator to the board with your tweezers
  • Unplug the wire connecting the vibrator to the board with your tweezers
Unfold motherboard from the screen (open carefully like a book)
  • Unfold motherboard from the screen (open carefully like a book)
Disconnect the two aluminum flex cables
  • Disconnect the two aluminum flex cables
The flex cables should be the only binding and after being removed should leave you with the separate screen
  • The flex cables should be the only binding and after being removed should leave you with the separate screen
Carefully dislodge the earpiece using the tweezers as shown in the first image After loosening the piece (if it will not come out from the back) carefully push from the front side with the safety pry tool (guitar pick) After loosening the piece (if it will not come out from the back) carefully push from the front side with the safety pry tool (guitar pick)
  • Carefully dislodge the earpiece using the tweezers as shown in the first image
  • After loosening the piece (if it will not come out from the back) carefully push from the front side with the safety pry tool (guitar pick)
Victoria
Membre depuis le 23/10/2014
94 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-4, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 5-4, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G4
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 173
