Introduction
This guide demonstrates how to propery remove and replace the front panel of an HTC HD 2.
Pièces
Aucune pièce nécessaire.
HTC HD 2 Touch Glas Repair
  • HTC HD 2 Touch Glas Repair
Ajouter un commentaire
Open the back cover and remove the battery.
  • Open the back cover and remove the battery.
Use a small Philips screwdriver to remove the four indicated screws.
  • Use a small Philips screwdriver to remove the four indicated screws.
Use a pry tool along the edges of the device to remove the broken or non-functional screen.
  • Use a pry tool along the edges of the device to remove the broken or non-functional screen.
Carefully pull the flex cable connections. Carefully pull the flex cable connections. Carefully pull the flex cable connections.
  • Carefully pull the flex cable connections.
Danach 3 tesa stripes lösen Using tweezers, release the 3 tesa strips. Using tweezers, release the 3 tesa strips.
  • Danach 3 tesa stripes lösen
  • Using tweezers, release the 3 tesa strips.
Kabel vorsichtig aus dem Kabelschacht ... Carefully remove the cable from its shaft. Carefully remove the cable from its shaft.
  • Kabel vorsichtig aus dem Kabelschacht ...
  • Carefully remove the cable from its shaft.
FLEX FLEX FLEX
  • FLEX
Einzelnd Einzelnd Einzelnd
  • Einzelnd
Flex Flex Flex
  • Flex
Aufklappen Aufklappen Aufklappen
  • Aufklappen
Vorsichtig
  • Vorsichtig
Mark Kruhse
Membre depuis le 10/11/2014
19 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 147
