Introduction
This guide is one of the longer processes, second only to the Logic Board, or the screen. Have a reasonably long time set aside to complete this guide.
Pièces
Aucune pièce nécessaire.
Carefully pull the rear cover from the back of the phone.
  • Carefully pull the rear cover from the back of the phone.
  • Place a finger beneath the small lip on the left side of the battery.
Ajouter un commentaire
Lay the phone down on it's screen. Lift up on the lip and pull the battery from the phone.
  • Lay the phone down on it's screen.
  • Lift up on the lip and pull the battery from the phone.
Remove the four black 3.5mm T5 screws from the back of the phone. Remove the four black 3.5mm T5 screws from the back of the phone.
  • Remove the four black 3.5mm T5 screws from the back of the phone.
Insert the flat end of a spudger between the midframe and the display. Slide the spudger along the seam between the frame and the display.
  • Insert the flat end of a spudger between the midframe and the display.
  • Slide the spudger along the seam between the frame and the display.
  • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
  • As it releases, pull the midframe away from the phone.
  • The volume control tab may fall off during removal. It can be easily reattached.
Disconnect the flash cable from its socket in the bottom of the motherboard. Carefully pull the cable from its groove in the frame, working your way back to the camera. Carefully pull the cable from its groove in the frame, working your way back to the camera.
  • Disconnect the flash cable from its socket in the bottom of the motherboard.
  • Carefully pull the cable from its groove in the frame, working your way back to the camera.
Pull the camera flash and cover off of the board. You may need to peel back the sticker that sits behind the battery. Work carefully. Excessive force can damage the camera or motherboard.
  • Pull the camera flash and cover off of the board.
    • You may need to peel back the sticker that sits behind the battery.
  • Work carefully. Excessive force can damage the camera or motherboard.
Around the camera is a thin shielding. Remove it with tweezers.
  • Around the camera is a thin shielding. Remove it with tweezers.
  • Using tweezers, remove the primary camera.
2 autre(s) ont terminé cette réparation.
Sam Luedloff
Membre depuis le 12/04/2011
715 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-55, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 7,688
