Introduction
Remove 4 Torx screws and 2 #00 Philps
First remove the back cover of your phone to expose the battery.
  • First remove the back cover of your phone to expose the battery.
Ajouter un commentaire
Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
  • Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
Take the battery out When reassembling, make sure that the battery contacts match up.
  • Take the battery out
  • When reassembling, make sure that the battery contacts match up.
Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
  • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
  • Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
Use the plastic opening tool to pry the clips off Insert the plastic opening tool along the seams at different points to it pry up This may require a bit of force. The USB port cover may fall off in this step.
  • Use the plastic opening tool to pry the clips off
  • Insert the plastic opening tool along the seams at different points to it pry up
  • This may require a bit of force. The USB port cover may fall off in this step.
Andrew Van Meter
Membre depuis le 06/10/2011
24 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 20-29, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 706
